Kilroy
Sorry if this is elsewhere, but I can't find it.
I'm adding relays to headlights on 04. 5. Tapped wire in headlight switch for lows and works fine.
Tried to tap wire for high just above headlight socket. When I checked voltage at this socket, without a bulb in it registered 3 volts with or without headlight switch on. Decided to try using anyway. It will not signal high beam relay to come on. Followed schematic by Stern, seems like everything should be ok, except where to trigger switch. If I put bulb in original socket it works normally.
Suggestions appreciated.
Thanks
Thanks
