I have an early (non intercooled) 91 that has puked its vacuum pump internals (or at least the ball bearing balls) into the timing gear case, and has taken a few bites out of a gear or two. I went to the parts store, and the part they showed for a vacuum pump was the little pod that goes on the side and/or bottom of the assembly. It is the part that goes between the pods and the P/S pump/ reservoir ass'y that I need. It has a cam lobe type eccentric that connects to plungers that plunge into the vacuum pods to create the vacuum. My problem is, where do I find one? No junkyards around here have any diesels, and the dealer is only open M-F 8-5. Cant go in there those hours- have to work. I would like to get it back running ASAP. Thanks in advance for any ideas. Will also post in first gen forum.
Daniel
Daniel
