Need valve cover gaskets.
TDR p.16 re; Pre fuel filter?
Bombing vs. Mileage?
Ive got some oil leaking out of the valve cover gaskets. Can I get them at a Cummins shop or do I have to get them at the dealer? Will I need anything else also? If Cummins shop can get them. Does anyone know the the part number?
Thanks Jeff H.
95 Dodge Ram reg cab,2500, T. M. S. Cummins Diesel,5spd, MODS,torque plate forward,star wheel forward,Plugged wastegate, K/N filter,dual exhaust 5'' tips,Lost muffler,fixed cat,Lost turbo silencer, ACCESORIES,ISSPRO turbo & pyro. gauges pioneer cd,Cobra Nighthawk c/b,Wilson whips. Shell Rotella in pan. 120k. on the OD.
Be Where Of The Big Bad Dees
Jeff, don't have a part number, but I suspect the gaskets would not be a problem at the dealer or Cummins. I've had good luck replacing the O-ring under the bolt head that holds the tappet cover in place. Just carry one of the old O-rings to Napa and buy replacements, they won't have a part number, but should have no problem matching up a replacement. They act as both a spacer and a seal and apply pressure to the gaskets. Always stopped any seepage for me.
"95" 3500, 4WHD, Ext cab. SLT, 5 spd, 4. 10 LSD, Rancho 9000's PacBrake, running boards, Mopar mud flaps, Isspro EGT, 50lb. boost, TST #8, no cat, muff or turbo ring.
Jeff,
If the o-rings are ok and everything is clean the gaskets should seal up ok. They are well made and can be used over. Cylinders 5 and 6 are kind of a PITA to get on just right so they take a bit of care to make sure that they are on correctly.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,BD valve body,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
Joe,
I found my valve cover gaskets were getting a little "Soggy & Bloated" at about 80K miles.
I replaced them when I adjusted my valves.
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust,Autometer Pyro & Boost gauges, Bosch 215HP injectors, Timing @ 14. 7 BTDC, JRE Stage III #4 plate 270/675, AFC spring kit,Pschotty Air, Optima Red Tops, Geno`s Exhaust Blanket, Synthetic lubes throughout.
HEMI®Dart,
That's very interesting. Some of my gaskets are original(I messed up a couple when I put the chrome kit on and had to reuse old ones). There is 142K+ on my truck and they all still look good. I've replaced the o-rings a few times because I've messed them up taking the valve covers off, but the base gaskets are ok. I take the covers off when I polish the chrome because it looks terrible if I do it with them on. Too much stuff in the way.
I replaced the gaskets on my '96 in April. The Cummins part number was 3902666
- about 22. 00 for the set of six from Cummins. Don't forget the previously mentioned o-rings as they don't come with the gaskets.
RA Dreher
Another source for the Valve cover gaskets on the weekend is at your local Case implement dealer. The current skid steer loaders made by Case have a 4 cyl cummins engine. The gaskets for the 6P (6 something) engine are the same as the Dodge Cummins. $24 for the 6pack.
Bubba
