The injection pump on my 93 D250 LE 2WD daily driver (290,00+ miles) has started a slow drip,,,looks like it is coming from around the throttle linkage.
The truck is still driving, but leaks a small (6" dia. or so) stain in the drive over the weekend.
I've been to two shops in the Raleigh, NC area. Both declined to try and rebuild it, and both said the part was no longer available. It seems that when I had it in the dealer's shop about 15 years ago, the pump was replaced under warranty with a reman unit. Didn't realize that until I took a pic of the tag on the pump!
The dealer I bought the truck from in '92 was closed down by Chrysler/Dodge last year.
I'm looking for a reliable place to purchase a pump (and/or have it rebuilt) and have it installed. I don't have facilities (or skills) to do this R&R myself.
I also need to do a re-build or replacement of the power steering pump.
I recently installed myself a Borgeson Steering shaft... that took out a LOT of play in the steering, but I'm also trying to find a steering box (rack & Piston?? I was told).
AND, I am looking for front coils, upper/lower ball joints, and control arm bushings.
It seems from reading the threads, that I should get the "Severe Duty" 7226s front coils to pull the front end up to where it should be and to keep the weight load from sagging the springs too much again. Moog springs/ball joints probably.
Is this a correct assumption?? My brother-in-law and I can handle the suspension work in his farm garage in Western North Carolina.
Lots of questions, and a lot of work to be done!
All advice appreciated.
