Need wire color or diagram for blower
Ball Joint Woes...
Balance Masters
I have searched threads and cant find what I am looking for. The a/c blower motor turns off when I raise and lower the steering column in my 2004. 5 3500. That seems to be the only thing that is affected. I would like to pull and splice that wire in the wiring harness at the connection under the column. Does anyone have a diagram or know which wire it is?
Thanks,
Jeff
Thanks,
Jeff
My 03 was doing the same thing. At one point I had lowered the steering column to replace lights in the instrument cluster and must have messed up the columns’ alignment. I had to replace the ignition switch because this problem burned the ignitions switch contacts. I still have problems when trying to turn the key to the accessory position.
