Hi everyone,
I'm a new convert with a 2013 Laramie Megacab I got to tow a travel trailer. My trailer tire pressure monitor system won't work well without an external antenna, and also want to put a ham radio transceiver in the driver side storage compartment behind the rear seat. I can run the TPMS and ham radio antenna cables in through a plugged hole in the floor under the passenger side storage compartment.
I want to run several small cables from the rear up to the console - the TPMS antenna cable, a remote control cable and an audio cable for the radio. In my previous (F150) truck I ran them under the carpet and they popped out inside the console. The cross members for the rear seat make that approach difficult if not impossible.
The Ram 2-way radio install procedure says to run them in a tunnel under the door threshold so I think I need to pull off the rubber door seal surround and pull up the plastic door sill. Are there any special tools required to pop the door sill, or is it just tabs in slots in the body? Anybody have a link to the procedure to pull the door sill and the trim panel between the door and the rear of the truck?
Thanks,
Al
Thanks,
Al
