Yesterday morning got in truck, waited for cycle of all icons, turned on the key and engine fired up normally. All functions on gauges looked normal, but when I put it in "R" and started to back slowly out of the garage, it felt like it was going to die and was "missing". Stopped and put in "D" and it started surging and would not take fuel, as if in limp mode.
I also experienced this problem once before when truck had about 8,000 miles on it. At that time I simply turned off the key and restarted and it has run fine ever since. This time I tried the same thing about five or six times with no effect. Finally, turned off engine and popped the hood to see if anything could be seen loose or screwed up. After starting up again 5 or 6 minutes later, it ran fine and hasn't missed a lick for over 125 miles of mixed driving... . truck now has 36,550 miles with all flashes up to date..... am planning on things stating to fall off real soon..... Oh yes, one other thing, when running bad, it seemed like I could hear a louder pinging than usual, sort of like a start up on a cold morning... ..... all service is up to date so that shouldn't be a problem... ... ... ..... my thoughts... ... possible stuck injector ????
