Needed Inline Fuel Check Valve :?
3500 Tire Pressure & Wheel Questions
Should we yank the converter anti-drainback valve?
Does anyone know of an Inline check valve that I can put in a 3/8" Fuel line. With hose connections preferred>
I heard that the PSD's use one ?
Thanks in advance for your help! :)
Todd, Thanks those are perfect!! and what $$$$ got to do with more Power/Bombing :D
CSutton,
Does anything get past you? :)
Yes I hooked up a second Carter pump from Napa. I have a head light relay triggered by the primary lift pump power wire.
Then the power wire from the relay runs thru a Hobbs switch so the second pump kicks in only when the psi at the vp44 drops under 10psi.
I then added a fitting to the fuel tank down near the bottom. Ran 3/8" line to the new pump then feed it the schrader valve port of the fuel filter banjo.
My pressure gauge does not bottom out under full throttle and my max boost went from 38psi to over 42psi !!!
Talk about Power!!:D:D
With the new 5" exhaust it screams!
