Needed
Ute ltd bed installed....
Which Gauges?
Needed: LE Experts!
When my new Mag-Hytec cover arrives, I will be swapping gear oil again. I'm not sure which one I should use for the front diff and eventually the rear diff (possibly the transmission later as well!). I see the products #703, 704, 9921 & 9922 are the gear oils. I'm currently using Royal Purple 75W-90. I spoke with someone from LE about a month ago asking for some info including dealers in my area (Michigan) and have not received anything! :mad: So any information you might have would be greatly appreciated! Thanks,
Tony
After 100k of Amzoil, I changed to Royal Purple 75-90 just because they happened to have it at the NAPA store I was in. It is supposed to have a limited slip additive in it, but just like the Amsoil, I had to add a bottle & a half of the Mopar stuff to keep it from chattering on turns. (Which doesn't stink anymore by the way)
I didn't have any problems w/ chattering when I put in the RP. It's been in for about 2000 miles now w/out any problems. I think i'm going to just keep on using it. Do you think the 75W-90 is good enough? Or should I switch to the 85W-140?
