Details here: TDR Privileges
I SAW A SMALL OIL LEAK UNDER MY TRUCK TODAY. OPENED THE HOOD AND DIRECTLY BEHIND VALVE COVER THEIR IS A ALUMINUM COVER AND IT IS SOAKED WITH OIL. JUST WONDERING WHAT IT IS. I DO HAVE THE TST ON AND JUST WONDERING IF IT CAUSED THIS PROBLEM ?
Jason maybe it is running out from under the plastic cover? Anytime you accidentally spill oil when adding any it runs under the cover then out at the back.
Which side is it coming out on? When you wipe it and sniff it does it smell like oil or diesel?
Just a little FYI . . . when you type in all caps it is considered SHOUTING
