I need help to figure this out. I changed out both ground cables Friday evening due to excessive corrosion. The ignition key was off. As I was putting on the right battery ground cable (bolting it to the block), my brother put the lug on the battery. the ground cable shcoked the dickens out of me. He disconnected the cable and I finished the lower install. As soon as we hooked up the ground cable to the battery the lift pump started running contiously and the intake heaters started smoking. The truck is running with a heavy miss on number 5 cylinder (the truck had a slight miss earlier). The codes are 1693 (compaion P code), 0216 (injection timing), 0380, 0382 (intake heaters). My edge is going crazy on the EGT it bounces from 86 deg to 1666 at idle or highway speed.
Does anyone have a clue about this? All of the grounds appear to be connected and no real codes other then expected.
