Any tips on reinstalling NV4500 back in my '99 2 w/d in my driveway on your back??? I shipped it to Standard Gear and Trans for rebuild and its now sitting on my trans jack for last 2 days trying to wiggle it in. My son put new pilot bearing in flywheel which was installed and I borrowed actual input shaft loaned to me by Joe Donnelly (thnaks Joe) to line clutch back up. And from searching previous posts I installed 2 - 1/2" bolts with heads cut off top right and bottom left to help align trans. Right now its about 1 and 1/32" out from face of bell housing. I know the clutch arm is on the trans bearing surface as I can slide it back and forth. Also, we are spinning the driveshaft in gear and we have not had spine contact yet as there is no resistance. Also purchased a video inspection camera to try and see whats going on thru the clutch arm hole but all I see is clutch fingers. The trans jack has several adjustments for angle and I have measured trans face to bellhousing face to make sure we are "square" to no avail. It would help if we were on a lift but we're not. We will continue to avoid any mechanical means of force. My 27 year old son has been grabbing the tail shaft and wiggling and trying to put forward pressure along with me up forward doing the same to no avail. I guess we'll try removing bell housing and mount to trans to try that method?? Appreciate any tips. I guess my arms are just too weanie to push it in.
