nerf bars for 3500 quad cab
New Clutch-South Bend
ottomind-- Who and How
anyone out here know anyplace I can get plain old black steel nerf bars with no rubber step to fit the 3500 guad cub? thank you.
white 3500 quad cab pase 2 electric sun roof very cool no leather all opstion air bags 90000 shocks 355 gears 6 speed 11. 5 ft fully loaded northland camper, and a 3 horsetrailer gauages are next
Originally posted by RICHIE 2:
anyone out here know anyplace I can get plain old black steel nerf bars with no rubber step to fit the 3500 Quadcab? thank you.
<font color = blue> You mean like these Richie?? #ad
Also, check out the URL link for more information on WAAG in my signature file below.
<font color = red>
(PS: Thanks Mr. Moderator for your assistance in "cleaning up" my html "IMG" tag codes... )
<font color = blue>
JMc
2001 Flame Red Sport 3500 QC, 5. 9L 24v Cummins, 4x4 Auto, 3. 54/LSD, 155 inch WB, Agate leather, Camper Special & Trailer Tow Groups , Sliding Rear Window, WAAG sidetubes with dually kickouts, Line-X UTR Bedliner & underseal, Grover Airhorns, Lance 1130 slide-in Camper, 60 gallon Aerotank, RS9000s, Reese Titan class 5 hitch, Roadmaster XX, in planning stages... . Gauges, Mag-Hytec, Exhaust Brake, Psychotty Air, 4" exhaust, Injectors, Rickson 19. 5" wheels, , Bill K. VB & TC.
[This message has been edited by JohnMcIntyre (edited 12-20-2000). ]
i second your opinion on the WAAG bars. I have seen them in person. Read all of thier website and ordered a pair for the new to me 98 12v 3500 I just bought.
98 3500 12v 4x4 Quad Cab SLT Larimie, All the bombing parts accumulating on my workbench. A few more on order, and a few coming from Santa.
80 Porsche 911 SC Turbo Look Porsche Club Racing Trackcar, Totally Bombed
Cannondale Killer V 900 SL
How much are the black WAAG bars for a 2500 QC? They look pretty good and I have been looking for a set of bars that went tire to tire so I can get to my tool box! Thanks.
Steve
John-
Those are the exact side tubes that I want. Did you get the steel powder coated? My other concern is that I have the Tork-lift frame mounted camper tie-downs, and I am wondering if they will interfere?
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, HO Cummins (ETH), 6-Speed (DEE), SLT+, 3. 54 LSD, Camper Special, Trailer Tow, Heated Leather, Sliding Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine oil temp. ), Weather Guard Diamond Plate Saddle Box, Tork Lift camper tie-downs, Mag-Hytec, Mopar Tow Hooks, AND functional Halo light!
Bigfoot 3000 10. 11 Slide-in Camper.
Originally posted by dresslered:
John,
(1) did you get the steel powder coated? (2) will they interfere with the Tork-lift frame mounted camper tie-downs?
<font color = blue>
(1) David - Yes, it's offered as a standard factory finish and should help to maintain the looks for a good few years. (see the details on their website for more info)
(2) I'm personally not familiar with the Tork-lift configuration - that's a question you'd have to ask WAAG in Van Nuys themselves. Phone: (818) 989-5008 or email < sales@waag.com > or < support@waag.com >
Hope this helps!
JMc
[This message has been edited by JohnMcIntyre (edited 12-21-2000). ]
Thanks for the reply, John. I am going to take some measurements and maybe some pictures and then I'll contact WAAG. I had the happi-jaks originally, but my camper is too stiff and was stressing them (that's the reason for the Tork-Lifts).
Dress- What do you mean the camper was stiff and stressing the Happi jacks. I just bought a 3500 for the biggest slide in we could buy. I had planned on using haapi jacks.
Hey Griff-
I think that we are getting a little off topic here and I would normally correspond via email except that I am about to leave town until after New years. So here goes:
I originally installed the Happijac system(including stabilizer bar) so that I could run out and purchase a new slide-in camper and immediately bring it home. I don't want to put down any brands, so I will just say that after much research I ended up purchasing a Bigfoot 3000. This is as heavy as they come as it is a "true" four-season camper (double pane glass and rated to -40 degrees C). The Bigfoot weighs in at about 3500-lbs. It has an internal aluminum frame which eliminates the typical water damage prone to the wood frames but makes it extremely stiff. Because of this, you must tie it entirely to the bed of the truck or entirely to the frame. If you mix the two, as with the Happijac (they tie to the front of the bed and the rear bumper which is essentially the frame) you can do serious damage to the truck bed and/or camper. The truck bed is designed to flex independently from the frame. Damage to the camper will be seen as cracks in the fiberglass. Damage to the truck will show up as bent bumpers, bending of the front bed, and cracking of the welds underneath the bed. Having both systems on my truck, I am convinced the Tork-Lift is by far the superior mounting method. I have heard that the wood-framed campers (i. e. Lance, etc. ) do have enough flex so that these problems don't arise (however, if it is a heavy camper, I would still go with the Tork-Lift). Tork-Lift makes both a rigid mount and a spring loaded mount (both very $$). Apparently, the best combination is to get the "cheaper" rigid mounts but use the Happijac spring loaded turnbuckles. The drawbacks of the Tork-Lifts are that they hang down at frame level when you are toting a camper, but the extensions can be easily removed with a single pin when you are not. Sorry for the long and off topic post.
Happy Holidays to all.
Sources of info:
1) http://www.torklift.com/
2) http://www.superhitch.com/
3) http://duedall.fit.edu/yellow/
4) http://www.happycampers.net/index. cgi
5) floods of email whenever this topic is brought up.
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, HO Cummins (ETH), 6-Speed (DEE), SLT+, 3. 54 LSD, Camper Special, Trailer Tow, Heated Leather, Sliding Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine + diff. temp. ), Weather Guard Diamond Plate Saddle Box, Tork Lift camper tie-downs, Mag-Hytec, Mopar Tow Hooks, AND functional Halo light!
