neutral position on electric 4wd selector
G56 fill and drain plugs
Exhaust brake vacuum pump failure
How does one get the transfercase to the neutral position when you have electric shifter knob?
Post back if you don't have an owners manual... I don't have mine in front of me, but I remember there are like a dozen steps to follow.
no tcase neutral
I don't have the manual handy. I recall it to be a simple procedure but it refuses to budge--the knob will not turn counterclockwise from 2wd or further from 4lo. I thought this would be the easy way to service/lube the drive shafts but it is becoming a confusing##%&@@#!!!!***
Andy
From my memory, step on brake and clutch if you have one. Then push small inset button just below switch with a pen or something small. Hold in for a few seconds. Probably with the ignition on. Reverse process to put back into neutral. This is in the owners manual, but was hard to find. Probably would be a good theft deterrent.
I agree with the last post.
1. turn knob to neutral
2. step on break & clutch if you have one.
3. push and hold little button to the lower left of the knob,I think!
