Ok, here's the dealio.
My '96 2500 4wd has a D70 rear with drums. Tires are 265-75-16s on stock steelies, and 3. 54:1 LSD diff.
I had a huge issue with the Right-Rear brake dragging heavily. I pulled it apart to find an all-but-worthless axle seal leaking, completely caking all the brake parts and drum with axle grease.
I ordered a new seal, hardware kit, brake shoes, and Wheel cylinders for both rears, and got to work.
Replaced both sides with everything, and cleaned up all the nastiness.
Brake would still drag, and seemed almost worse.
Removed the parking brake cable, and that took care of the dragging. Ordered a new RR park brake cable (still waiting on it. )
NOW, the same wheel locks up on slight pedal pressure, mostly when it's been sitting for a few hours. I've taken it apart, and it all is still clean, and nothing looks effed up, so I don't know why this is still doing it.
Doubtful, but would air in the brake lines cause this? The action seems to be more common when it's damp outside, like early morning, and the likes. All the back-plate plugs are in place... Or is it more of an adjustment issue? I searched here this morning, and found some info regarding lockup due to maladjustment. .
