JTryles said:The next issue is the fact that DC has moved the lift pump to inside the fuel tank will limit even further the amount of power you can add before fuel starvation occurs. Should be intresting to see what happens when folks start to BOMB them...
JTryles said:I'm "assuming" (you know what they say about that though) that a given pump "pushing" fuel all the way from the rear of the truck to the front will underperform that same pump "pulling" fuel the same distance. I could be wrong! I do know it's a lot easier to pull a load up a hill then to try and push it though... .
realsquash said:It actually tends to work opposite of that when it comes to fuel pumps. They always seem to work best as pushers. I just wonder if they are using the same pumps as gassers do?
Andy
jwilliams3 said:600 and 610=same box
Alan Reagan said:Are all 05s the new 610?
