Hey all. Finally got the big beast installed and filled up. . a bit of a chore but not too horrible. Was able to do it on the ground and by myself. . you will see how I did that latter part in a bit. .
So ordered the tank and it arrived on truck, covered with cardboard and strapped to a long pallet. . perfect shipping. .
/webdata/photopost/data/795/medium/2012-03-05_13-44-46_437.jpg#ad
OK, First thing is the tank was painted, not powder coat. . good thing I planned on bedliner coating it. . scotch it down and use spray kind. . can add more later if needed. . coated the whole thing with about 2 coats.
/webdata/photopost/data/795/medium/2012-03-05_13-44-58_810.jpg#ad
This pic is with the coating on it. . notice a neat thing that the rear elevated section has a vent hose so that part will fill. . this hose goes over the crossmember...
/webdata/photopost/data/500/medium/2012-03-10_17-01-44_971.jpg#ad
Jack up rear of truck as high as your Jack stands will go. I had 1/4" clearance on new tank sliding under frame on cardboard. .
Old tank removal. . Piece of cake. 2 nuts, 2 straps, drop driveline, disconnect hoses and wire. . all done. . I had 7 gal left in my tank and it wasn't bad to drop with a floor jack. just balanced it.
Pic of old to new tank compare...
/webdata/photopost/data/500/medium/2012-03-10_17-00-23_421.jpg#ad
Now first thing is to modify the truck... have to cut a body loop off the bed next to the frame. . used a cut-off took. . then they say to cut the bolts from the old straps. . found out you don't need to cut the front one. . just the rear...
/webdata/photopost/data/500/medium/2012-03-10_17-04-06_370.jpg#ad
/webdata/photopost/data/500/medium/2012-03-10_17-04-38_498.jpg#ad
/webdata/photopost/data/500/medium/2012-03-10_17-04-23_685.jpg#ad
This is the front one. . as you can see there is enough room for it to remain
/webdata/photopost/data/500/medium/2012-03-11_10-32-13_868.jpg#ad
When you take the lines off the top of the pump unit, the innards of the connector stays on the unit. . very carefully take off these things and replace to the lines. . they provide extenders with Dodge lines but different ones. . so snap on the extenders to old lines then these will go on the unit top. . no modify to electrical connection...
/webdata/photopost/data/500/medium/2012-03-10_17-04-56_21.jpg#ad
See the blue and grey plastic? there are little keepers you use a tiny screwdriver to get under and slide off then insert into old lines.
/webdata/photopost/data/500/medium/2012-03-10_17-00-34_470.jpg#ad
Unit coming out of old tank easy just lower part a little tight coming out. . a little more room on the new tank. . Re-use O-ring and bolts to snug down top. . not too tight. . don't crush. . See above pic.
