uhh, I detect a bit of [censored] here.
Several folks have called and or emailed that they are noticing that the tach is showing approximately 50 RPM lower for the same speeds.
I wish I could 'splain' in lil words for you. Like I stated in my previous post... there are some results we never expected and this one is one of them.
One individual installed his Scotty Air III while at a DTR show and the next day was quick to point out this result. He went and drove his truck again with his factory air box and then the Scotty III again... and... . lower rpm with the Scotty III.
Its got me a bit baffled too. However, this has been a more then random report from folks. My only guess is that theres enough air to burn the fuel more efficiently so that the engine does not have to work as hard at 'cruise' to produce the same speed.
I'm reaching with this answer/theory as its one of those things that made me go ... hmmmmmm.
Also, perhaps since there is a large air inlet behind the grill with this system that while cruising down the highway at 70 mph it does 'RAM' more air into the engine. Or should I say, makes more air available cuz we all know that the turbo dictates the air if theres enough there.
I simply stated the feedback we are getting and I really do not have a logical answer for this. Maybe the large air volume and pressure is altering what one of the sensors is seeing?
There is a difference between 'horsies' and torque. If one was to add 50 lbft of torque then my next guess is that you have more torque at the same rpm and do not need it all. Just a guess.
The seat o' pants meter from all who are using this system shows a better power band... in the real wolrd, going down the road.
We never saw the HP claims on the dynojet that other systems claim, we do feel it on the road though.
