New Automatic Wind Delector installed
Exhaust piping?
pyro gauge probs
The Utra-Fab Automatic wind deflector is on... I added some LED Lights to the framework before putting it to the truck. Have 5 on each side.
I can unhook the wires from underneath the truck if I want to remove the unit but I think I might just leave it on unless I need the stake-holes for something.
The shock units have to be removed to lay the panel flat and there are pins that pull down on rubber stops when flat so it don't rattle when touring around. All the parts are great and installation was easy... .
You can see I bought the lite-rider Tonneu Cover so the stake pockets are available and they roll up just inside the frame when towing.
Here is the LED Light I am using. It is a 12 LED Light that has 2 pins to push onto a mounting bracket. About $21 for light and bracket Each.
Might try to get the vinyl stickers that is on the 5th and put them on there... A pic of a mountain and "RAPTOR" word. (Keystone Raptor Toyhauler... Look in Towing area under slideout covers)
