Engine/Transmission (1994 - 1998) new bombs, numbers on the dyno!
2nd Gen Non-Engine/Transmission Michelin Tires
2nd Gen Non-Engine/Transmission won't run
Well guys my new bombs paid off in a big way! (370's, 191's, 3kgks, #10plate, 16cm2 non-wastegated exhaust housing, AFC springs. ) my best run yesterday at the brawl was 432. 7/959. 3! :D
I would like to thank Scott (proram) over at RDP, for a job well done! Scott did an excellent job working with me, and an even better job tuning my truck up for the show! so if there is anyone in the PA area what needs good work, i deffintley reccomend RDP!
I am thinking of putting in a set of 215"s after some transmission work with a 3K spring kit. Should I just go to 370's? The 215,s are easy to find and quite a bit less expensive is why. Don,t want to waste the money if it won,t do that much good. Any opinions?
some good numbers! i dynoed 277hp and 697 with my plate out, now the injectors are in and i would like to see what they do
Carl in my opinion i would definately go for the 370s lots more power they do smoke a bit more though, i dont know where you are looking at prices for the injectors but from what i have seen they are both within about 50 bux of each other, but i promise you will like the 370s more.
