New Bombs On The Way!!!
03 Back Rack
Gooseneck Hitch install with Airlift Bags
I mustan been a real good father this year... ... ... ... the lil woman has given me the nod to order
Rickson 19. 5's steel powder coated blackwith ss trim rings and the Yokohama ty 303 tire 285's
2 1/2" leveling for the front end by DT with new trac bar, and the upper and lower control arms that move the wheel forward a half inch.
Rancho 9000 shocks
Honda EU 3000 generator for the camper
I Love This Woman, maybe tonight she will put a dab of diesel fuel behind her ears too :D
cheers, Kevin
:eek: Whitmore:confused: your sick. Look what being around that sewer gas has done to you. Maybe you need to start taking a shower before you go home and put on some clean clothes-underwear too. You do wear underwear?Wife:-{} Whitmore I guess she just gives in to you.
You will say anything Kevin to keep getting the nod. :D
I've met Mrs. Whitmore and she's pretty darn cool! This only confirms my beliefs. Hey Kev, can you have your wife talk with mine again?! This time talk some bombing sense into her?:confused: :D
BUYER BEWARE
I just received my DT products I have been waiting a month for. Out of the trac bar, links, and dual shock kit the only thing I can use unless it does'nt work either is the trac bar. I have not fit it up there yet to make sure it will work but... ... . the links have the wrong size sleeves in the bushings, Dave at DT said he new he sent the wrong ones, he figured I could just take them to a machine shop and have them drilled out (wrong) so he is building new ones for my truck, so check this out before you take your truck apart and make sure they are the right sleeves. The bolts on the lower links won't fit through the current sleeves. The dual shock mounts will take some cutting and rewelding of brake line brackets, new brake lines to reroute them. The lower brackets themselves have the wrong size upper holes drilled in them and the bottom don't line up. The shock mount position is right where my hard brake lines are. If I were to mount them where they are suppose to go they will be at a funny angle and there is no way the shock will line up, they won't mount flush. I am hoping I got the wrong ones, if not this is a poor design. No one answers the phone so I am waiting for a call back so I can send them back. Good thing I checked all this out before I started tearing my truck apart..... :(
If there is anyone out there that has made these shock mounts work could you let me know and post some pictures... ... thanks
Just to add, this is a new problem so I will post later on how all of this is handled and the outcome. I do not want to hurt someones business, so don't come to any conclusions yet... thanks
