New brake bleeder valves in Geno's catalog
New to 24v Diesel
Power without smoke???
Howdy all,
In the new issue of Geno's Garage catalog, and on their website of course, they have a new product that sounds promising. New bleeder valves for the brakes that have a check valve in them so you can bleed your brakes all by yourself. They only list a set for front disc brakes, but not for the rears on the 2001. 5 trucks, which I have.
Was wondering if I could just order two sets of these and use a set on the rear brakes as well... ... ... ...
I'm single, and so don't have anyone to help me bleed brakes, etc. . These sure would be a big help if they will work.
Thanks,
Tom
I assume these are the Russell speed bleeders? If so, they work great. I had a set on my Jeep. Took them off when I converted it to 4 wheel disc, and need to get some new ones for the new calipers. If the rear calipers use the same size/thread bleeder as the fronts, then they'll work. Otherwise try Summit racing as they sell them as well and may carry ones that will fit the rears.
What you need for single man brake bleed
1) A large (preferrably) non breakable bottle
with lid.
2) A length of rubber tubing that is
the correct diameter to fit snugly over the
bleeder nipples. This can be anywhere from
a couple of inches long to say 6 feet.
3) A means of fastening the tubing through
the lid of the bottle with the end very near
the bottom of the bottle.
What you are trying to fix is when you let
off on the brake pedal it tends to create
a suction that will pull (suck) air back
in of the bleeder valve is open.
How the bottle and the hose works: You
connect the hose to the bleeder valve before
opening it. You open the valve and walk
to the cab and pump the pedal. Because the
brake fluid goes down the hose and into the
bottle, when you let off on the pedal it
suck the new fluid that you were bleeding
back from the hose into the slave cylinder.
You walk from the cab and close the
bleeder valve and you are golden.
A couple of points: You need to either bleed
enough brake fluid to get the level of the
bottle over the end of the hose OR pre-fill
the bottle with brake fluid. I like the
first part better because the point of bleeding
the brake is to get that new fluid into the
slave cylinder and push as much of the old
fluid out as possible.
You do not have to rely on anyone but yourself
to do this. So you do not have to piss off the
wife, girl friend or significant other to
help you. You will not get brake fluid squirted
in you face or other places that you do not
want it. All of the fluid goes into the bottle.
I was shown this method by a very good racing
mechanic. I have used to this method on
several vehicles and it just works.
I am really particular when it comes to my
brakes. If it isn't right it does not get
driven.
I wish I had a digital picture to show you.
You can use the small plastic container
that comes with a might-vac (vacuum brake
bleed kit) for a started. The one that
came with my mighty-vac was setup correctly.
Using a bigger bottle with a larger
base and longer hose works better.
Don't think about using the vacuum bleeder.
It does not work even half as well as the
brake pedal. The brake pedal is your friend.
