I just replaced the front pads on my '98 2500 2wd.
Pressed the piston in with the bleeder open and installed as normal.
I did a quick check of the sleeves in the dust boot the caliper slides on - seemed fairly smooth.
After changing I noticed I had a noticably firmer brake pedal, but it does pull to left a bit under moderate to heavy braking.
This weekend I'm going to take the calipers apart and do a better job of cleaning and lubing the sleeves and gaskets / wipers.
Question:
Are the left and right brakes lines (front) self equalizing?
Are they tied togther at the master cylinder to keep the pressure equalized?
What else should I check?
The old pads were worn, but it did brake evenly prior to changing.
Question:
