New Bullydog downloader & Monitor--WOW!!!
Manual trans changes coming???
How Can I find Rear axel ratio?
I Just installed a New downloader from bullydog on my 04`. It is by far the most powerful of any of the dodge modules I've tryed. The new outlook monitor has alot of neat toys to play with Too. The monitor gives you 2 pyro readings, boost,rpm, speed, torque, hp,icp pressure, 1/4 mile times, 0-60 times, speedo calibration & diagnostics. Well worth the wait!! :--) Oo.
Not much info on their website. It looks pretty plane jane but offers some nice features. Interesting that the Ford version allows access to DTCs (Diagnostic Trouble Codes) but the Dodge version doesn't mention it. Got any pictures? Anyone else using one of these and care to compare it to the TST box?
That thing ain't even close to the TST!Same as the rest of the 0/50/100 boxes. The TST is at least good for 150hp or more. And more torque than you will need on the street. I think the only one that will come close is the Edge Juice when all the bugs are worked out.
If you guys will read closely, I never said it has more than the tst-But! I havent tryed one either. I will also say that I believe this is as much Fuel that this motor can handle "SAFELY". The de-fueling mode is a nice feature that will keep most Normal people out of trouble. It will defuel around 1300 or so on the #1 pyro.
My Bad! I forgot the "you have tried part". The TST also defuels at any pre set EGT you select. from 500 deg to no defueling.
Try one of these and you will be :--) :-laf
I also have the new bully dog downloader which isnt out to the public yet and i have tried every box out there and this download will beat any of them box for box this one does bully dog justice
i agree that the tst box is impressive. but it is not good for 150. the best box dyno number i got with bullydog timing and fuel was 146 over. With edms and that same box 6 inch, intake ,my 03 put 544 to the ground on a dyno this download is extremely more powerful than that
the downloader for the dodge has dtc's as well as a pto option four settings the horsepower numbers are extremely modest. the extreme download is well over 160,170 it is very impressive. every body that has rode in my truck could not beleive the difference and the truck before the dowload was already strong
Hmm,,
Forgive my skepticism but judging from the signup dates and the amount of posts we may have some underhanded advertising going on. Not knocking Bullydog as I know nothing about them but I want an objective opinion when I choose my box, not a salesman for the company.
If Im wrong I apoligize but lets keep it legit.
Hey how about some info on your profile. What trucks are you guys running these on. It seems kinda wierd that you both joined tdr yesterday and all of a sudden you have these great numbers . Whats up with that?
Well the TST on mine went from 190 stock to 357 0n 6X6 and that is good for 167hp gain and it was not even up all the way!By the way my 02 had BullyDog III's in it and they were great!but I aint gonna give ya this one on the box!!I agree someone is trollin!!
PS Big Mak how about lockin this one out!
Actually, according to Bully Dog, it's a monitor. Doesn't mention anything about being a performance box or a downloader.
"Imagine setting a downloader on the highest setting and being able to pull your large trailers. This sleek in-cab controller/monitor/gauge set features advanced technology providing you high tech performance like no other product on the market. The Bully Dog Outlook Monitor takes priority access of your engine and gives you control over your vehicle's power levels with a flick of a switch. It also allows you to set emergency de-fueling points based on exhaust temperatures. "
It says setting 'A' downloader, not the 'Outlook Monitor'.
Bully Dog's site also states:
"Compatibility
Works with ALL diesel chips, performance modules and downloaders. This one of a kind monitor will de-fuel the engine regardless of brand type used. "
Their site also states:
"The Outlook Monitor is designed to work specifically with Bully Dog's Rapid Power and Dyno Dominator performance modules, but is also compatible with ALL diesel chips, performance modules and/or downloaders available on the market. "
If it's a performance enhancer and not just a monitor (although it's looks like a darn good monitor), the above statement makes no sense.
My . 02!
Jim
