Shelby Griggs
Well, after 229K, I think I might need a clutch and a bit of TLC on the NV5600, getting a bit hard to shift, especially when cold, so I am having a shop pull the transmission and then shipping it to Standard Transmission and Gear for them to go through it. I have every confidence that Standard will do well with the transmission, they will be adding the Power Lube Package also.
I am less sure about what to do with the clutch. I initially was thinking South Bend Clutch (1947-OK), but I am not sure after reading a number of posts here. My use is pretty much stock. I carry 8000-10000 pounds on the truck at all times and with a small cargo trailer I sometimes can reach 12K. I do a lot of highway miles, BUT also a LOT of stop and go driving while on project sites too, I don't think I need anything more than stock like operation, the truck is stock power wise and since it is at 229K, I would expect a new stock clutch to go another 200K or so. I wouldn't mind the SBC pilot bearing upgrade, BUT other than that, what is SBC going to really do for me over another stock clutch? Another possible benefit I might get from SBC is a stronger hub, I use the exhaust brake almost 100% of the time, while I am not loaded super heavy, the stronger hub of the SBC is supposed to do better with heavy EB use.
From my reading here on TDR there "might" be some drawbacks to SBC???
I have read of a couple of instances of flywheel issues where the starter had engagement issues, etc. Those might of been isolated incidents, I don't know, but in both cases a new flywheel was required AND a new starter or at least the starter drive. One disadvantage of going to an independent shop is that they don't warranty customer supplied parts, even if SBC made it right, I still am out the R&R if something goes wrong. The only SBC shop in Oregon is a three hour drive away, they have an excellent reputation, but it is much more convenient to take it to a good local shop about a mile away, not to mention the fuel cost, currently $3. 25 a gallon and going up daily.
I also am under the understanding that the SBC products make more noise? Is that true for all of their products or just the more aggressive clutches?
I really would like to support SBC as their reputation seems to be outstanding and they support the TDR, BUT I want essentially stock pedal feel or better AND stock noise level or better, is that going to be the case with a 1947-OK kit from SBC? Cost isn't too much of a consideration, the 1947-OK seems to be within in the price range of both ordering from Dodge or an independent clutch warehouse that sells Luk products.
I need to make the decision fairly quickly, the truck goes in for surgery Monday morning and I have to select the clutch and get it here before the transmission gets back, any advice from the TDR members will be greatly appreciated.
SHG
SHG
