I just replaced my clutch with a NEW CLUTCH and now my pedal is waaay soft and doesn't fully disengage. I have to start it in gear or mash the pedal to the floor and jam it in gear. I re-used the hydraulics and made sure the little rubber boot was on the end of the slave cylinder push rod. Do I have to upgrade hydraulics too, or can I just get a little longer push rod? I know these are non adjustable clutches and I REALLY don't want to pull it all apart again.
Wyomingcowboy,
Two different issues presented, lets take the easy one first.
Pedal effort.
If you have a truck with a normaly worn out "thin" disc and JUST replace the DISC and release bearing only reusing the old clutch cover,
your pedal effort will be reduced. This is a characteristic of a standard diaphragm clutch. We can back this up with test graphs. Couple that with a new release bearing (the rotating part is not the issue, the SLIDING part is) that goes on with new grease in the grease groove, a cleaned up guide tube with a film of grease, dab of grease on the pivot points and your pedal effort is back to AS DESIGNED. Lets test your new clutch, easy pedal and all. Take it for a test drive, get it into 5th and in a section of road that is an uphill grade, make like you are passing a truck, nail it.
Q. Did the RPM and MPH remain syncronized? If yes, clutch did not slip, try again with loads, still holding? Enjoy the easier pedal.
Not releasing cleanly. Many possible issues, lets hit the hydro's first.
The 13" clutch used in the NV5600 needs about 1/2" of bearing travel for release. Easily delivered by a correctly functioning standard hydro system. I don't have your trucks clutch/hydro's etc history, but I sure do like to rule out ANY chance that this is an external problem rather than an internal problem first.
We have done quite a bit with the hydros at work and these systems can be confusing, I admit. First no bleed screws or vent, I actually like this because in this application, that means we are not going to WASTE DOT 3. It is a simple process to test the hydro's independant of the clutch, we have a video on youtube showing the procedure, really it is a bleeding, make that burping procedure that ends with a test. Basically you use a steering wheel puller (after removing the S/C but still hooked to the pressure line remove its pushrod and boot) to block the piston, simple. Now the test, push on the pedal with your HAND (use your hand, we don't need to pressure test is as much as we need to do an effiency test) this system will go rock hard in 1/8" clutch master cylinder pushrod travel with a couple of pounds applied at the pedal with your hand. If you have an air bubble it will get hard but it will travel further before it gets rock hard. This loss of effective travel is what KILLS a system from releasing completely. I recently demonstrated a Ford Ranger system (No. 1 problem system) and actually added via a T and some brass parts the ability to run it w/o any air in it and then with the T and a valve to a trapped section of clear plastic incorporate a SMALL air bubble into the pressure line, it stopped releasing on the spot. Maybe next week, I'll take a picture to show the setup. We used it for training demonstration.
How to fix if it fails.
1. Look for leaking or weepage, if found consider R&R of that component.
2. Chasing the bubble out. Best to remove the entire system as a complete unit, not hard at all. Take to bench.
3. Watch youtube video Bleeding w/o bleed screws.
4. With M/C positioned with p-rod pointed down at 30 degrees or so, remove cap.
5. Slowly compress S/C by hand and have someone watch for bubbles in M/C reservoir. If bubbles, repeat several times. Tap on S/C, line and all the way up to M/C. Chase the bubbles out the top.
6. Test for 1/8" to rock hard.
NOTE: Will not be effective if the M/C is horizontal, this prevents air from getting to the exit in the M/C fluid flow path.
Longer S/C push rod IMHO and experience will not do anything. It is the VOLUME of fluid displaced by the M/C that determines how far the S/C pushrod will extend.
Other possibliities for no release exist, but lets start with this, let me know what you find.
Nick:
We did an R&R on an '04 that they didn't grease the sliding portion of the bearing, pedal effort was off the chart and I actually broke the M/C to pedal pin trying to push the pedal.
RustyJC:
The F/W has a flange that centers it on the crank, but for resurfacing they as you describe must use the crank contact surface as a reference, not the projecting flange, ouch.
WC, good luck.
Gary
