Engine/Transmission (1994 - 1998) New Diesel Owner/Need some help
Engine/Transmission (1994 - 1998) blocking waste gate
Engine/Transmission (1998.5 - 2002) do ALL 02's have 9cm turbo?
1st time Diesel Owner/Need some help
:confused: I NEED SOME ADVISE ON SETTING UP MY TRUCK
ANY HELP IS HIGHLY APPRECIATED
I WANT TO BE MAYBE AROUND 300HP AND MAYBE 650FTLB
AND WHAT ABOUT THE GEARS SINCE I AM RUNNING 305 TIRE AND NEXT SET I MIGHT GO TO 315'S
1st - take the CAPS LOCK off.
2nd - what truck do you have? Fill out your signature.
3rd - how much money do you want to spend?
4th - Welcome to the TDR!:D
1st- sorry no more caps
2nd-i did fill out the signature and i dont know why its not showing/ 98 12v 2500 4. 10gears 305/70/16
3rd-well surely money doesn't grow on trees but i am willing to spend it to do the job right
i tow 30ft toy hauler
4th-thank you
Welcome
Hi PK, where are you located?? Put your location in your profile too. This way if someone is nearby you can get some local help and advice.
If you happen to be in Michigan, or northern Ohio you are welcome to contact me and get together, I have a '98 12v you can take for a drive and see if it has enough HP for you. Has DTT Trans too.
Send me a PM if you are nearby and we'll set up a time.
Hope this helps, Greg L
