well not exactly what I was hopeing for but the truck is still together so I guess I can smile.
1st run fuel only 356hp 753 ft lbs. Boost hit 55lbs ran great, never cleared up the smoke.
2nd run fuel only, couple less hp didn't brake it to help spool. 352/740
3rd run 1 stage, wastegate set to dump at 30lbs hit 57lbs made 424hp 900 ft lbs
4th run 2 stages, pegged 60lb guage, made 487hp 1005 ft lbs before poping the fuse for the fuel pump at 2550 rpms might of cliped 500 but barely. Smoke cleaned up pretty good but still had some left.
So now what's the problem, I have huge amounts of air 55lbs on a low,low drive pressure turbo and huge amounts of fuel that is still not being burnt. I'm gonna guess the timing is the problem not giving the mixture time to burn. That and it's the only thing I have yet to do.
Oh well it was fun all the remus boys did well, Adam Cornell uped his record to 1374hp, Kevin Chaffey hit 908 and a monster vp truck they just built hit 651 with single turbo on fuel.
I'll get some pics and videos up as soon as I figure it out
