I got mine for $160 shipped... a little savings...
The pto covers are actually quite thick, I would not be afrain to drill and tap one for a sending unit.
I guess I just got stuck in a rut... I always drill them, and braze half of a steel collar to the inside (1/8 NPT) for my sending units... did this to several things I have.
steved
I don't have access to a welder of any sorthopefully nothing will leak, or it's going to be messy
When you tap, don't run the tap in too deep... run it in just enough to get the threads clear through, then try your sending unit. If it will thread through the cover, stop, if not, run the tap through a little further (not much) and try the sending unit again... repeat this until the sending unit has a full thread through the cover, and still has some exposed on the front...
The NPT is tapered... run the tap completely in and your sending unit might actually be loose whne the threads are bottomed.
steved
Thanks or the tip!
Maybe a rubber/metal washer on both ends as well?
And were abouts in the PTO over? smack in hte middle? or near the bottom? (never popped hte cover on my transmission et)
Anyone see the "fast cooler" type coolers in the latest Petersen's rag??
I'll have to get the name tonight, but they were nicer (IMO) than the fast coolers...
steved
