New Fastcore Hi-Flow Intake Manifold for Cummins Engine
excellent on line reference for understanding turbos
Atlantic Cummins, NC
Fastcore CFM+ Intake Manifold. It looks a good bit like the Banks and ATS arch manifold/big head units that have become popular with the 2nd/3rd Generation trucks. However, the bolt pattern is the same for 12 and 24 valve engines so the high performance/aftermarket units fit all generation turcks that share the same bolt pattern.
The CFM+ flows 40 % more air than stock and, reported to flow much more air than any other aftermarket intake now on the market. Not only that but it delivers COOLER air to the engine due to it's material of construction.
The manifold is made from high-temperature composite that transfers heat 900 times LESS than all other performance manifolds made from cast aluminum.
www.cfmplus.com
I just checked the link. I didn't see one for the 12 valve. Does look cool for the others though. Hope its available for mine :confused:
p-Bar said:
I don't think he will be doing one for the 12v because it is so differant than the 2nd and 3rd genners
Or maybe because there will be no hp improvement on the dyno?
Bob
