new flash for ecm
Alternator Capability versus Loads
Psycotty Air Filter
Just took my truck in complaining of bad mileage(10-11mpg), and was just told that they flashed it. I had taken it in before for the reflash, but my serial number didn't require the flash. Now I'm told that there was a new TSB flash just released last week. #ad
Hopefully, I'm getting better mileage now. Just so you know I have a 99 QC 3500, auto, 3. 54's. It is a welding truck and is near or slightly over GVWR, and gets driven at 65 or 70 on the highway. It has 26000 miles on it, so it's broken in.
I am starting to think that they just gave me the 18-11-19? flash in order to shut me up, as I have a friend with a 2500/360 auto combo, packing around the exact same thing as me who can get 12 mpg. Doesn't make much sense to spend $6200 for the diesel option if all I get is 10 mpg. (except for the power potential and the cummins grunt #ad
Better yet, they are required to put a sticker under the hood with the Flash Number on it. What is that number?
Originally posted by tmacc:
Davey,
Would please post the TSB number? Inquiring minds would like to know.
Thanks.
I had my engine reflashed and I still don't get good Mileage this is what I am getting Unloaded with a cab high Shell Flat Ground Freeway and Highway 65 mph 4300 Foot Elevation. Temperature Ranges Bettween 100 and 20 Dedgrees.
By the Way I used planetfeedback.com to register a complaint with DiamlerChrysler USA
Here is another little tid bit from The RV Buyers Guide. www.rvbg.com/weight. cfm This chart gives you what you should be getting for the Total Weight of the Rig. Check it out.
My actual mileage performance is as follows. Read Before you buy and get it in Writing.
Fuel Flow For 1999 Dodge Quade Cab Diesel
#DIV/0!
Date Beginning Odometer Ending Odometer Miles Traveled Gallons of Fuel Miles per Gallon
15527
9/3/00 15527 16074 547 51. 089 10. 70680577 Towing
9/10/00 16074 16266 192 13. 848 13. 86481802 City
9/17/00 16266 16535 269 24. 331 11. 05585467 Towing and City
9/20/00 16535 16859 324 26. 335 12. 3030188 Towing and City
9/29/00 16859 17185 326 22. 993 14. 17822816 Highway
10/6/00 17185 17451 266 16. 038 16. 58560918 Highway
10/21/00 17451 17772 321 22. 7336 14. 12006897 Highway
11/7/00 17772 18151 379 25. 764 14. 71044869 Highway
11/17/00 18151 18504 353 25. 28 13. 96360759 Highway
11/30/00 18504 18828 324 23. 064 14. 04786681 Highway
12/11/00 18828 19171 343 24. 119 14. 22115345 Highway
12/22/00 19171 19554 383 26. 924 14. 22522656 Highway
12/31/00 19554 19846 292 20. 253 14. 41761714 Highway
19846 -19846
0 -15527 #DIV/0!
Total 322. 7716
