I have read many posts regarding the issue of installing a new fuel filter and not being able to start the truck; however, I am still not convinced that the lift pump died. Before I spend a $100 on a tow, I thought I would see what yall think. The truck has over 140K miles and I have changed the filter many times in the past and never had this problem (it always takes a little cranking, but eventually starts). Just before I pulled the canister off, I drove the truck until it warmed up to prevent a cold start. I drained the canister and replaced the filter. Probably should have poured the fuel back into the canister but didn't (like I said, this is the way I have always done it). Is there a way to prime the fuel system other than bumping the ignition between run and start? When I open the drain valve on the canister and try to start the truck I get NO fuel coming out of the line. I took the canister off and tried the same thing and get NO fuel dumping out of the filter housing. Filter was wet, but canister was not full of fuel. I cracked the nut on the first and third injector and cranked and got no fuel there either. Tried a little ether and it almost made it but died. Next step is to have it towed down to Clint's shop (ouch!). What is the best aftermarket lift pump? How difficult is it replace? Any help would be greatly appreciated.
-Keith, Golden CO
-Keith, Golden CO
