I just had a fuel pressure gauge installed on my 05 and at idle and crusing it reads about 9 psi and I have pulled it down to 5 psi and was told that you can pull it down to 3 psi with out hurting anything. I installed a 2 micron fuel filter from GDP after the stock filter with there big hose kit that has an ID of about 3/8" compared with the stock 1/4" that was feeding the IP from the stock fuel filter. The gauge tee was put into the hose down stream from the 2 micron fuel filter. I had the tap put there so that I can moniter the condition of the filters so that I know when to change them if I get some bad fuel.
