Engine/Transmission (1998.5 - 2002) New fuel pressure guage - reads ZERO!!
2nd Gen Non-Engine/Transmission light switch on 98.5 vs. 99-02
Engine/Transmission (1998.5 - 2002) anti defuel boxes?
Ok, got my mechanical fuel pressure guage all hooked up and went to bleed the air out of the line from the Shrader valve to the isolator and I noticed the pump wouldn't cycle. It groaned a little once and that's it. So I started the engine and slowly loosened the bleed screw and the motor started dying like I was letting air IN. Apparantly the lift pump is dead?? Guage reads 0. Any ideas?
Yup ... another one bites the dust ... time to visit your local Cummins dealer. :{
Since you are buying a new one you might look into relocating it back near the tank, lot of guys here using the "Vulcan" kit and seem happy with it.
Kevin
I wonder how long it has been like that... ... That is exactly how I found my LP was dead. 3 stock LP's later under warrenty I put a FASS in. Now I have 19PSI at idle and 15-16 WOT all day!!
Fix it soon and pray your VP is not soon to come.
John
