Ok another fuel pump question I bought an aeromotive pump and a racor fuel/water separator I want to eliminate the factory lift pump and filter the question that I have is powering the pump do I run a toggle switch with a relay or can you run the factory lift pump wires back to the new pump can someone explain the pros and cons of each thank you for any help Aaron
