Hello all, got an issue I'm trying to trace down, so I'm going to give a description of all the symtoms I've discovered so far and we will see who can come up with the correct answer to my problem.
Here is what is happening:
the issue started out as a random rare occurance, but has gotten gradually worse to where it is almost all the time now.
the problem is a flicker in the electrical system that affects the dash lights, headlights and will occasionally cause the engine to stumble. This will happen with the headlights on and the headlights off. This will happen with the engine running and the engine off, key on or key off. I just replaced the Alternator, it went out a few weeks ago, but it was doing it before it went out and is still doing it after replacing it, that was the original alternator with about 300k on it.
I have a secondary fuse block on the truck and everything powered off of it works fine, no issues. I don't believe it's the headlight switch as it affects more than just the lights, it's not the alternator or power fluctuations from it or the battery. I'm running a single odessey 2100 cca battery in the truck. It happens when the engine is cold or hot, dry or wet outside, cold or warm outside. I've never replaced a relay on the truck, so they are all original, 10 years old and 300k miles on them.
Does anyone have a wild guess as to what the problem could be? I drive 1200 miles every other weekend in the truck to see my kids and don't want to be stranded during one of those trips.
Morph
Morph
