New guy with questions
Automatic Transmission oil
4" exhaust housing adapter for early03-04 trucks
I just purchased a ram 2005? 2500 4x4 ctd and see a lot of post talking about the 2004. 5 can anyone tell me when the production dates on these start and finish? Mine was manufactured on 8/04 and is 325 h. p. 5. 9 . I assume mine is a high output 600 correct? Sorry for all the stupid questions but trying to get up to speed here with everyone else.
Thank you
Diamond G Racing
Yes it would be an HO, HPCR High Pressure common rail fuel system. 325/610 (at the flywheel) I think they run around 290/500 at the rear wheels. The 05's have the fuel pump in the tank and the intercooler is different and won't handle as much boost which should,t be a problem unless you Bomb it some. i believe the turbo's are designed for just under 30 #s of boost. Pretty sure I'm on track here if not someone else will chime in. Good luck and enjoy your new truck.
