Hello all…
I have been lurking around this forum for the last few weeks in an attempt to educate myself on my “new to me” 93 350 xcab 4x4. I purchased it in California, drove it to Texas and it currently has 227000 miles on it.
The previous owners did some up grades and they listed as follows.
1. fuel pump replaced and prime handle set at halfway
2. Turbo waste gate set at max boost (?)
3. Air filter box Swiss cheesed w/ K&N
4. Injector pump modified and turned up for more fuel and pressure(his words)
5. 235 hp injectors
6. Trans. Rebuilt 4/05 has rv torque converter, shift fit, 3 coolers, and Heavy duty flex plate.
7. Leaf springs added and re-arched 2” rear, 4” front. Front shock mounts lowered.
8. 4 core radiator.
9. Gauges, pyro, rpm, temp
Other various repairs have been made recently to the vehicle, common stuff.
Although, I don’t have any comparison, I believe the trans. downshifts too soon. As soon as I release the gas pedal a little it down shifts.
The throttle valve cable adjustment does not seem to help. The steering is looser than I like. I have bought a Borgeson shaft and was wondering if I should replace the steering box while I am at it. It runs like a “scalded ape” but the previous owner suggested that I remove the water separator because it leaks air and causes rough idle and power loss. It does not idle rough and I have no comparison on power. It blows no significant smoke, which I prefer. Any idea how to confirm some of the items listed above? Any ideas on the shifting issue?
So far all I have learned has been from you folks, but I have to say it is a lot of info to take in at once. Thank god it is not a newer model. All in all, it’s a great truck. But, I wish it were a four door and more after market parts were still available. I appreciate all the help so far and am looking forward to perusing this forum. I will have pictures as soon as I have the running boards installed and, uh…. wash it.
Thanks again
SWhite
sTw
5. 235 hp injectors
8. 4 core radiator.
Thanks again
SWhite
sTw
