A couple of months ago installed an Aurora 4000+ turbo system works great. While passing could get 40# boost without pushing too hard. Wanted to play safe and installed a set of ARP head studs. While at it checked valve clearances. All were pretty good except # 6 which was tight - made adjustments.
Truck started and ran smooth except power is way down. Max boost @ 90 MPH WOT = 35#. Fuel press = 12#, rail press = 2000+#.
Rechecked valves = OK. Found a speck of dirt in the little hole of the air pressure/temp sensor at the air filter - blew it out. Low end power seems pretty good but 60 MPH acceleration is still slow. Smarty was set on 30HP. Went to 60HP - not much change. Besides screwing with a perfectly good engine where did I go wrong?
