An update - Correctly rebuilt stock injectors, (new tip, balanced and correct opening pressures, correct closing, tight shut off, etc. , etc. ,) will cost almost the same as new injectors. I would suspect that with the tightening of diesel emission requlations, etc. rebuilds that are correctly done should have almost the same life as new injectors. It is also very hard to find a set of rebuilts on the shelf. Most injector shops that I talked to need the cores and will turn them around in a few days.
