Got 3 of the 5 and 300k on the clock. I'll try adjusting valves and go from there. Thanks, RB
I may simply have a worn-out engine and is one of the reasons I had truck in shop, using oil, BUT two shops now say blowby isn't excessive for age and mileage and OFI checked turbo, visible smoke both under load and deacceleration and basically nothing major noted. Recommendation is to change from 5w-40 to 15w-40 and see if consumption decreases. Truck is using a quart at about 2000-3000 miles and that is acceptable "officially", but I will say that is about 3x-4x what it was doing up to around 300k. Acceptable usage per Cummins while in warranty is 500 miles per quart. I think that might be just to CYA and limit warranty claims, but that is what they say.
Your engine might be worn but it is far from worn out. A qt every 2000-3000 miles is not much. I didn't pull my original engine until consumption was at a qt every 800 miles. Changing to 15W40 is likely not going to change anything. The hot viscosity of the two oils is the same. If you are concerned about your engine's health I suggest you submit an oil analysis and take a look at wear metals. It will also tell you if your air filter is doing it's job. If silicon is over 10 it is not.
When you start seeing tin and brass, then it is time.
If you can swing it do the injectors now if possible.
I think they are failry reasonable for new ones vs rebuilt, even with all the recent price shifts in stuff.
Sounds like you got a good run out of yours
