Ok, so today I installed my new lift pump from Cummins. My 2000 has 123K on it and the lift pump had no pressure, but you could hear it run (so who knows how long it was like this). I just installed my fuel pressure gauge on Saturday which told me the pump had no pressure, but the truck ran fine up until this point. The electric pressure sender is hooked into the schrader fitting on the injector pump. No mods to the motor, just gauges and high flow air filter.
The fuel pressure with the new lift pump at idle is 15psi. Slightly off idle and up to 1500 rpm, the pressure drops steadily and once you are above 1500 rpm and starting to step into it harder the pressure goes to zero (actually slightly below). Needless to say, at wide open trottle there is no pressure.
Do you think I got a bad lift pump, or could it be something else? Is this something the Cummins dealer should replace without question?
