Engine/Transmission (1998.5 - 2002) new LP can hear cycle on/off ??
I just did the vulcan line kit/ and relocate kit along w/ a new LP.
1st off, man . . is that LP loud on back there !!
2nd, its so loud that I can hear it cycle on and off when at idle . . is that normal????. . it constantly runs when im driving down the road though.
I can't hear mine other than when I first turn the key on, though the straight piped thing might have something to do with that. :D
If you mount the bracket on Rubber mounts that will help. I also put a piece of close cell foam above it. SNOKING
The LP should not cycle on & off at idle. When you turn the key to the "on" position you should hear it cycle on for a few seconds and then off. Once you start the engine the LP should be running steady whether it's at idle or WOT.
Mike
Just noticed you're from Minnesota. If the temps are cold and your grid heaters are going on and off (that's normal) then your LP might be getting less voltage and sound like it's cycling. Maybe that's what you're hearing.
Mike
