Hello to all. I'm obviously new to the site. I found this site after losing my lift pump on Wed. (89000mi) What a wealth of information! I'm sure you can help solve my dilema.
I've read and read and read all about the dreaded lift pump.
I was up 'till 3 this morning reading posts.
Wed. I started out of the parking lot at work, then, nothing. It seemed like it was running on 3 cylinders. It only ran like this for about 3 minutes while I turned around and got it back into the lot and waited for a tow.
Thanks to this site I was able to get the correct and new edition of the pump and harness from a Freightliner dealer for $140.
The removal/replace was straight forward enough, just a little cramped kneeling on the valve cover. I changed the fuel filter just in case the pump let go of something. I also bled all the lines sequentially from the lift pump to the injector pump.
Sounds good so far right?
Well. Then it wouldn't start. I bled the lines again, no air came out anywhere. Should start right? Nope.
I then read some more and found some tricks here. I tried starting it again and got it going, about like it was on Wed. night. I tried the WD 40 trick I found here, and that helped a little. It ran rough for about 4 minutes, and then started to smooth out and approach something close to normal. Then it died.
I haven't been able to get it to restart since.
I read today, while waiting for my membership and acct. info that a gas soaked rag might help?? Really? I'm willing to try just about anything at this point.
I apologize for the long post, but I fugured I'd give as much info as I could to help the thought process out.
