Bhale's post is right on the money. read it a couple of times. The #11 plate and the AFC kit will really wake it up and take it up to the limit of the clutch. No sacrifice in economy either, and only a small haze of smoke when you really stand on it. After those mods, the price of admission rises, custom clutch, turbo, bigger injectors, etc. , but you may be very happy with the fuel plate, AFC, and gages. The fuel plate is one of several factors controlling fuel delivery and is partly responsible for the HP "personality" of the engine which is taylored by AFC springs, adjustments, and plate changes.
I am very happy with my set up which recently allowed me to tow 25,000 Lb (scaled) gross over Jelico (4-5% grade for miles, I75, Tennessee) at 52 mph in 4th over, (same as 5th direct) at 1750 rpm, 25psi boost and 1100 deg EGT preturbo. I know I could have ran the rpm up and gone 65mph with higher EGT and 35 psi boost, but the water temp climbs on this long grade. It was a walk in the park for the Cummins. Stock with this load, 35 mph, maybe.
Try the AFC kit, #11 plate (385 Hp, 685 Ft-Lbs torque) and gages.
And, Welcome aboard!!
