I need some fresh ideas from people who have had the old 5. 9 cummins. I recently bought this motorhome with one in it, the previous owner had gotten a gut full of it too. When it is running, it performs nicely, smooth idle, good acceleration, plenty of power. The motor did on two occasions die when coming to a stop light, and starting is a matter of cranking and cranking, and cranking. Onec in a great while, it will fire up like it should. Not often though.
I am an aircraft mechanic and a certified auto mechanic as well, so I have a little basic knowledge, but at 68 years old, am not up on the newer stuff.
The previous owner had become convinced it was electrical. A Cummins tech told him the batteries went down so low the shut off solenoid was shutting it down, and keeping it from starting. He had replaced the alternator, all 6 batteries, all fuel filters of course, and the converter when I came to own it. In the 200 miles home, it died no less than 5 times! In each case starting aids, waiting, or whatever finally got it going again. It appeared to even possible be heat related, the last 100 miles were uneventful, sun had gone down.
I got all the manuals together, and started off. First thing I did was put new batteries in again, larger amp capacity. In checking, I found the lift pump (diaphram type) was totally inoperative, plunger rod had end off it. I put on a new one, bled the air all the way to injectors, and finally started. Let it run a while, shut it off, and repeatedly started it again and again, maybe 10-12 times. So happy with it now, I went home. Today I tried to start it, same old routine, crank for ever and ever.
This evening reading the book, it says one place to keep your foot off the accelerator when cranking, in another place it says to give it full throttle when cranking at less than 60 degrees because it RICHENS the mixture! I had not tried that one yet. It does not appear to smoke either when cranking or when it starts. If you give it a shot of starting fluid, it lights right up and idles and performs quite well.
I see plenty about the newer ones wrecking the injector pump when the lift pump goes out, will that happen on the old VE44 Bosch as well? Could that be my problem? The fuel shut off has to be working well, pumps plenty out the loosened injector connections when cranking.
Come on, I am tired of this, can someone give me some fresh ideas? I might add that this is in an 88 motorhome with only 40,000 miles on it, so it has sat a bit in its life.
