Engine/Transmission (1994 - 1998) New member w/Q's
2nd Gen Non-Engine/Transmission Front spring's/leveling ?'s
Engine/Transmission (1994 - 1998) --Need OEM Parts--
Hello to all!
I've finally joined after months of soaking up info as a guest user. Hope someone can answer a few questions:
I'm looking to hit 500hp for the least amount of $$ (hoping for under $2k in parts). Truck is currently stock except for an upgraded P7100 (don't know what fp or springs; waiting for Piers to get back to me on that). I know I need pyro,boost, and fuel pressure guages prior to bombing, but what should be upgraded to get me to 500?
anyone have dynos on BHAF vs an expensive cold air intake?
any recommended 4" pipes?
Thanks!
:--) wow no gauges!!! I have simmilar goals in the 500 range im at 360ish and need a charger, dv's, injectors, head gasket (time not failure), 0-ring head, timing ajustment, after cooler, trans rebuild tripple disk t/c, and a detroit locker but before all that I may get a diffrent 12v I want 4x4 or I may convert mine ???
