Hello Everyone , My name is Pete here in NW Ohio and I am a proud new owner of a 2002 CTD, traded in my 96 1500 for this beast and have been smiling ever since. Joined your website here and have been doing a lot of reading about the in's and out's of CTD ownership. Very first thing I have done is bought a set of gauges for the pillar to keep an eye on things. Ended up with Isspro EV pyro,boost and fuelpressure, did the install today, all went well. boost and pyro seem to be running where they are suppost to from reading various post, the fuelpressure however is another matter. Installed with banjo on bottom of filter housing, used isolator, all readings are steady, no vibration. on initial start up shows around 12 psi in idle, but after about a minute or so drops of sharply to around 5 psi or so might stay there for a couple of minutes and go right back up to 11 psi for highway cruise, stays there for a while and drops to 1 psi, and after a while go back up to 11 or so. Keeps cycling like this at about 4-5 minute intervals, when the pressure rises or drops, it if fairly quick, like turning the engine off. no change in other engine parameters. At first I thought maybe airbubles, but pressure is pressure right? I assume that my liftpump is the source of my trouble (38000 miles) but the only doubt that I have is that it does not seem to be a typical failure. Any comments?? Also for warrenty work on the engine, can I go to a Cummings dealer or do I have to go to a Dodge dealer?
looking forward to tap this great Collective knowledge base
Thanks Pete
Thanks Pete
