Well the lake is doing great! The weather ssuuuuuucccccckkkkkkeeeedddd on saturday, but as usual Sunday was beautiful. It was so nice Today that I went ahead and launched the boat. It's so cool to cruise the lake when it's glass smooth. Sometimes a little chop a small wakes make for a smooth rocking ride too. Depth finder said water is 70+ feet deep over by the dam. Last fall the deepest spot I found was about 45 feet.
This was the first run towing with gauges. Took the 5th wheel and will probably leave it at the storage lot for the rest of the summer.
I observed the following conditions. Sounds like things are working real well.
Flat ground, not towing: 75 mph, 2000 RPM, 600F EGT, 9 lbs boost, 140F trans temp
Towing 9500 lbs: 65 -70 mph, 1700-1800 RPM, 850F EGT, 900 uphills, 10 lbs boost, 20 lbs uphill, 150 trans temp.
Trans temp stays low even 4 wheeling in sand. Spikes to 170 idling in park. Fluid shear?
