Engine/Transmission (1998.5 - 2002) New Noise
okay on start up when the engine is cold and temps are in 30s/40s I get a squeel to a high pitch canary sound goes away usually in 5 minutes I tried to isolate the sound but the truck is just to noisy to isolate. so I'm guessing the best way is with a cold engine remove belt and check the idle bearing and the water pump see if there is any play. does the fan/clutch make the same sound or would I see a different issue if it was the fan/clutch. I know genos sells a dayco bearing its cheap and I checked the water pump on rockauto.com but what about cummins water pump should I look there first. I replaced my belt about 25k miles ago I guess it could be that but looks good. so tell me you thoughts or if you have a different way to trouble shoot this. my water pump is not leaking.
2002 HO 6-SPD LB 4X4 QC HTT 62/14 SB-FE SMARTY TST PM3 MACH 4'S, RINGED AND STUDS, AFE/2:eek: "SILVERLINE D/PRICOL PYRO,BOOST,FUEL FASS 150, VULCAN 1/2 DRAW-STRAW, VULCAN 3/8 FUEL LINE AND FITTINGS, DSS 03 TRAC-BAR DSS BOX TURN-OVER BALL, RIDE RITE AIR BAGS. SUPPORT 17'' KMC BLACK HOSS, 315/70/17 MICKTHOM BMTZ'S 6" RCD LONG ARM LIFT AND DE-BADGED FOR FUEL MILEAGE. :-laf
Probably the belt, but if not the power steering pump reservoir may be low & the squeeling may be air in the system.
thanks I will try this. if it is the water pump does anyone have a good water pump source? I do have a cummins close. is the pump a cummins or is it a bosch?
thanks for the input I will try this when it the next non rainy cold day. but not like the cold out your way. I was stationed at Ft. Leonardwood Mo. I will check my belt it is pretty new but its a cheapie belt.
Try flushing the power steering system/up grading to a synthetic.
Bob
I will try the power steering fluid idea I didnt think about the steering because it would make this noise at idle and not moving
